DSC_1537 by jeznewsome, on FlickrSince I had the rear while out yesterday anyway to replace some sprocket fasteners and lock washers I offered the rear wheel up and have a few questions for those that have been there before:
- - I would like to retain an 'upper' position for the rear caliper if possible, though I have GSXR calipers (both upper and lower mount) and the carrier plate. Is there an easy route to fabrication of a 'bent' torque arm that will clear both the forward edge of the larger tyre and also the RHS Rear shock?
- I will be fitting a 530 chain and sprockets (inc a 5/8" front offset?) and believe that appropriate gearing is 17/48 or 49?
- Anyone got some advice on the length of chain required (nos links) or is it a case of buying a 120 link chain and just cutting appropriately?
- Spacer dimensions I'll work out once I have the C&S and torque arm sorted out, but any advice / guidance would be appreciated.
