1100 Suspension and Wheels Change
jeznewsome
Post by jeznewsome » Fri Apr 26, 2019 6:15 pm
A little searching on eBay has netted me a set of GSXR 750 (93) Wheels, Forks, yokes, bars, calipers front and rear (2 bikes worth) so though I still plan to ride it standard for a while I will want to fit the stuff at some point this year, whilst keeping the bike as original as possible such that it could be reverted if required.
ImageDSC_1537 by jeznewsome, on Flickr
Since I had the rear while out yesterday anyway to replace some sprocket fasteners and lock washers I offered the rear wheel up and have a few questions for those that have been there before:
  • - I would like to retain an 'upper' position for the rear caliper if possible, though I have GSXR calipers (both upper and lower mount) and the carrier plate. Is there an easy route to fabrication of a 'bent' torque arm that will clear both the forward edge of the larger tyre and also the RHS Rear shock?
    - I will be fitting a 530 chain and sprockets (inc a 5/8" front offset?) and believe that appropriate gearing is 17/48 or 49?
    - Anyone got some advice on the length of chain required (nos links) or is it a case of buying a 120 link chain and just cutting appropriately?
    - Spacer dimensions I'll work out once I have the C&S and torque arm sorted out, but any advice / guidance would be appreciated.
Thanks in advance and there'll be a similar set of questions undoubtedly when I offer up the front end!
Re: 1100 Suspension and Wheels Change
Post by Uncle Bob » Fri Apr 26, 2019 9:23 pm
For 530 sprockets generally 17/48 is the standard, but I went 17/49 after a few calculations, but now find this a bit to revvy for me. I will probably go for 17/48 or maybe even 47. I bought a 120 link chain and found I used 114 links.
This however was based on a 17" rear with 130/90 tyre so if your tyre is a lower profile then you may need to adjust. Here are some useful sites:
https://gsxkatana.wordpress.com/2011/05 ... onversion/ - mentions the GSXR 5.5 rim
http://www.suzuki-katana.com/katana_gearing.html - some GSXR stuff there
https://www.gearingcommander.com/
https://www.rbracing-rsr.com/calcsprocketdiam.html
Someone else will have to answer the brake torque arm question!
jeznewsome
Post by jeznewsome » Sat Apr 27, 2019 12:39 pm
That TNK arm is lovely.......sadly it appears that they are discontinued :(
But it is a good idea and the design may alleviate the need for a bend even the brake caliper on top. Certainly food for thought though might be tricky to get made (expensive too)
I'll have a look at bandit torque arms but I am fancying something alloy. I'll keep looking.
Thanks.
Post by Uncle Bob » Sat Apr 27, 2019 3:20 pm
If you are doing this don't forget to start a thread in the Project section so we can see how you are doing :-)
Good info for anyone else thinking about it as well.
jeznewsome
Post by jeznewsome » Sat Apr 27, 2019 3:48 pm
Roger
jeznewsome
Post by jeznewsome » Tue Apr 30, 2019 5:31 pm
Hmmm...... Might be heading for the wheel change sooner rather than later. Currently sat on the bike by the side of the road with a completely flat rear tyre.
As noted when I picked the bike up it was fitted with tubes...... So no chance of a roadside repair.... DOH.
RAC called.......... I guess I could be here some time!
Sent from my G8341 using Tapatalk
Post by Uncle Bob » Tue Apr 30, 2019 8:34 pm
Hope you got back OK, without too much delay.
jeznewsome
Post by jeznewsome » Tue Apr 30, 2019 9:23 pm
Took well over 2 hrs before recovery came but the guy was sensible with the bike and everything in one piece when I got home (apart from the air in the rear tyre).
Image2019-04-30_10-19-25 by jeznewsome, on Flickr
Fairly sure that I have been very lucky and not had a puncture since my 650 Kat 28 years ago.
Post by fossie » Wed May 01, 2019 7:40 am
It is the downside of the RAC , with motorcycle they have no other way but 3rd party collection, my work bikes through the company are RAC ....longest wait 11 hrs ....my shortest 5 hrs.!
The recovery through Peter James is SOS ....the guy who comes out first carries you on .
Obviously get tubeless ASAP eh! They do fit.
jeznewsome
Post by jeznewsome » Wed May 01, 2019 8:15 pm
fossie wrote:Obviously get tubeless ASAP eh! They do fit.
Yup first thing that I'll do once we get back from Hols in Ireland.
