Grab Rail for Pop up
SamK
Has thanked: 11 times
Been thanked: 64 times
Re: Grab Rail for Pop up
Post by SamK » Sat Mar 07, 2015 9:13 am
Looking forward to it :)
I may have to copy you, if I can find the rest of the parts...
Katfish
Has thanked: 28 times
Been thanked: 29 times
Post by Katfish » Sat Mar 07, 2015 9:15 am
I had a rack made, using the ventura rails as a template.
Andy...KOC 298
Snap, Crackle & Pop Up
payton6uk
Has thanked: 1 time
Post by payton6uk » Mon Mar 16, 2015 10:49 am
Using took the CBR600 kit:
We cut down the side arms to match the length of the existing bars.
Using the brackets in the kit we cut/twisted them to fit the existing frame fixing points
Cut the spacers of the existing givi kit brackets and welded them to the new brackets
Drilled 4 holes into the Givi Frame, welded collets I the holes to reinforce them
that basically was that...
The added bonus of using the spacers is the main arms of the rack stick out about 1/2inch making them perfect for grab rails
Still need to finish it, think I'll get it powder coated for a better finish (I'll post a picture when finished)
Thanks again Sam for the advice...
From this
From this
Using these connection points
Fitted
Fitted
The new Brackets
The new Brackets
before finishing
before finishing
SamK
Post by SamK » Mon Mar 16, 2015 4:58 pm
You've done a good job there.
Now I just need to find that box of bits and practise my welding :)
SamK
Post by SamK » Mon Apr 20, 2015 7:26 pm
I went for a slightly different take on the subject.
Still using the same CBR600 rails but used as well as the standard rail.
Drill a couple of holes in the rail. 16mm one side for the threaded spacer and 10mm the other for the M8 bolt holding it in. The plan was to hold the threaded spacer in place with the rear bolt and then weld them... however, when I switched my welder on, it didn't want to spark :(
A quick spray with Plastikote to tidy them up.
Discreet without the Givi rail fitted
All ready for a wet weekend in Manchester :)
payton6uk
Has thanked: 1 time
Post by payton6uk » Mon Apr 20, 2015 8:28 pm
Looks very professional.... very discreet, looks very nice with matching white box.
