front wheel spindle
Re: front wheel spindle
Post by callyboy » Sat Jul 14, 2012 12:38 pm
Well that was easy :D :D
Post by callyboy » Sat Jul 14, 2012 1:34 pm
Wahoo onto to page 3 !!!
Ok my hunt for a correct size bearing would appear to have hit a wall :(
I need a bearing with a 15mm bore 40mm diameter and 12mm width. Cant seem to find anything that size. However i did find a bush/sleeve which will fit inside the 17mm bearing bore and sleeve it down to 15mm which is the usual Suzuki wheel spindle size. Would that work ?
Or......I could just give up and sell the wheels onto to someone else who has 17mm spindles anyway and use these wheels that I picked up for a tenner today :shock: :shock:
Thoughts and piss takes welcomed.
Katman
Post by Katman » Sat Jul 14, 2012 2:05 pm
Is it the Mk2 Impulse wheels that you're trying to fit?
TNK do a spacer http://www.tnk-eng.com/1framepage%20top2.html" onclick="window.open(this.href);return false;
KOCUK 046 Jez
to be continued
Post by callyboy » Sat Jul 14, 2012 3:04 pm
Yes they are Jez. Cheers will have a looky.
Pete ;)
Post by callyboy » Sat Jul 14, 2012 3:15 pm
Cant read it Jez. Must have to enable japanese characters or something :(
just seeing squares(as opposed to stars !!!) :lol:
Katman
Post by Katman » Sat Jul 14, 2012 4:58 pm
Google translation for you
4.50-17 inch hole GSX-R series is set for mounting 17φ Bearing & color (can be mounted tire size 160).
Hub, rotor parts support is available from the normal in the transplant of 400 Katana.
※ vehicle photos, but has been changed to the swing arm for the impulse, we are also compatible with normal arm swing.
PRICE
\ (Excluding tax) \ 5,000 (tax included) 5,250
★ ★ diversion information
(3.50-17), (4.00-17) Rear wheel transplantation is possible with no processing impulse system (3.00-17) front wheel, the system impulse GSX-R400 system
KOCUK 046 Jez
to be continued
Post by johnr » Sat Jul 14, 2012 9:06 pm
thats a mk 2 400 impulse swingarm!
Katman
Post by Katman » Sat Jul 14, 2012 10:07 pm
johnr wrote:thats a mk 2 400 impulse swingarm!
KOCUK 046 Jez
to be continued
Has thanked: 80 times
Been thanked: 72 times
Post by sparki » Sun Jul 15, 2012 9:36 am
simply bearings list a 15 x 40 x 10 bearing..... that'll be fine imo. as long as it's snug against the inner spacer you'll be fine i recon...
KOCUK - 241
Post by bobster » Sun Jul 15, 2012 6:16 pm
If you use a thinner bearing there will be an extra 2mm gap to take up as the wheel spacers needs some thing to butt up against................before the wheel will tighten!
