front wheel spindle
Re: front wheel spindle
Wahoo onto to page 3 !!!
Ok my hunt for a correct size bearing would appear to have hit a wall
I need a bearing with a 15mm bore 40mm diameter and 12mm width. Cant seem to find anything that size. However i did find a bush/sleeve which will fit inside the 17mm bearing bore and sleeve it down to 15mm which is the usual Suzuki wheel spindle size. Would that work ?
Or......I could just give up and sell the wheels onto to someone else who has 17mm spindles anyway and use these wheels that I picked up for a tenner today
Thoughts and piss takes welcomed.
Is it the Mk2 Impulse wheels that you're trying to fit?
TNK do a spacer http://www.tnk-eng.com/1framepage%20top2.html" onclick="window.open(this.href);return false;
KOCUK 046 Jez
to be continued
to be continued
Cant read it Jez. Must have to enable japanese characters or something
just seeing squares(as opposed to stars !!!)
Google translation for you
4.50-17 inch hole GSX-R series is set for mounting 17φ Bearing & color (can be mounted tire size 160).
Hub, rotor parts support is available from the normal in the transplant of 400 Katana.
※ vehicle photos, but has been changed to the swing arm for the impulse, we are also compatible with normal arm swing.
PRICE
\ (Excluding tax) \ 5,000 (tax included) 5,250
★ ★ diversion information
(3.50-17), (4.00-17) Rear wheel transplantation is possible with no processing impulse system (3.00-17) front wheel, the system impulse GSX-R400 system
PRICE
KOCUK 046 Jez
to be continued
to be continued
also compatible with normal arm swing.johnr wrote:thats a mk 2 400 impulse swingarm!
KOCUK 046 Jez
to be continued
to be continued
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
simply bearings list a 15 x 40 x 10 bearing..... that'll be fine imo. as long as it's snug against the inner spacer you'll be fine i recon...
If you use a thinner bearing there will be an extra 2mm gap to take up as the wheel spacers needs some thing to butt up against................before the wheel will tighten!
