1100SZ Rear Shocks
VaVaVoom
1100SZ Rear Shocks
Post by VaVaVoom » Mon Aug 15, 2011 7:55 pm
Hello again.
Can anyone recommend a decent pair of aftermarket shocks please? I don't want cheapos but equally can't afford the exciting stuff.
I'm looking in the new Hagon price bracket but a couple of mates reckon Hagon's aren't that good. Any thoughts?
I've decided to completely rebuild the bike properly and once I'm ready to start I'll post a Project topic.
Cheers everyone.
Evan
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Re: 1100SZ Rear Shocks
Post by Katgeezer » Mon Aug 15, 2011 8:03 pm
Nothing wrong with Hagon's mate,good quality,decent price and work well. Not gonna set the world on fire like Ohlins etc but are a fraction of the price. You can also get Ikon's for a bit more money (old Koni's) which are arguably better than Hagon.
VaVaVoom
Post by VaVaVoom » Mon Aug 15, 2011 8:16 pm
Thanks. I appreciate that. I'll have a look at the Ikon site. I really just want something that will do a solid job and not look far off the originals, as I'm trying to tastefully modernise my bike as subtly as possible so it looks like a standard bike from across a car park!
Been thanked: 198 times
Post by Pedda » Tue Aug 16, 2011 10:00 am
Had some Konis on my Kat back in the day. Made a big difference to stock shocks!
VaVaVoom
Post by VaVaVoom » Tue Aug 16, 2011 11:49 am
Yeah. The Ikons look really good. The dial adjuster is certainly in keeping too. I'm not sure about black springs though. As they are rebuildable I will likely go for these as I'm sure they'll last.
Thanks for the advice.
Post by johnr » Tue Aug 16, 2011 3:58 pm
hagons are good too, they will allow you to specify slightly longer or shorter than stock and also will fit stiffer or softer springs as well. i have a set built for sidecar use that were made with 75% stiffer springs, a propper firm ride they give i tell ya!!
VaVaVoom
Post by VaVaVoom » Tue Aug 16, 2011 7:55 pm
Thanks John. Would you order the Hagons directly from Hagon then? Stiffer springs would be good as I'm a big lad!
Post by johnr » Tue Aug 16, 2011 8:06 pm
yes, definately, order direct from them and they will make them to your spec. back when i was running sidecars, we all used to build outfits up and the first thing we did was order the heavy duty shocks from hagon.
VaVaVoom
Post by VaVaVoom » Tue Aug 16, 2011 8:19 pm
Cheers. I've been looking on the Hagon website and when I type in my bike model it says only the road shocks are available. I fancy the 2810 shocks though. Probably better to give them a bell eh?
By the way John - what exactly is the Nissan silver car paint you've mentioned as a close match to 13L?
