My 'New' 650
Cold Snail
My 'New' 650
Post by Cold Snail » Wed Jan 12, 2011 11:01 am
It was a bit of a bi*ch to start this morning, I'm going to need to set it up with a good service before it goes on the road.
More photos here.
http://smg.photobucket.com/albums/v45/c ... =slideshow" onclick="window.open(this.href);return false;
Edit: And now with added video.
As you can hear, it's sucking in a bit of air through the rubber(s), so I won't do anything to it today, but it should be an easy fix.
Cold Snail
Re: My 'New' 650
Post by Cold Snail » Wed Jan 12, 2011 12:35 pm
I know, it needs one desperately.
The old white box is still on the other 650 that my mate now has, I've arranged a rack for this one and then I'll have a look for a suitable relic* once it's on.
*Fibreglass I hope.
Re: My 'New' 650
Post by callyboy » Wed Jan 12, 2011 1:59 pm
Looks good Paul.Well worth the money.
Re: My 'New' 650
Post by fossie » Thu Jan 13, 2011 11:53 pm
See told you it was a 650 seat that was modified by cutting the base.( Anorak or what?)
You need a 550 kat seat .
Don't worry people the rack is on order , from some dodgy geezer Manchester way , who happens to have one for 650 he don't need.
Oh coldsnail mate the forks you were going to stick on to save doing the fork seals won't fit in the yokes as those on the bike are 550 and narrower gauge than 650/750. Just a thought.
Cold Snail
Re: My 'New' 650
Post by Cold Snail » Fri Jan 14, 2011 10:14 am
It looks like I'm nicking the yokes off my 1100 then.
Mind you, it might be easier to do the seals on this one as getting to the 1100 would involve a lot of moving stuff.
Has thanked: 80 times
Been thanked: 72 times
Re: My 'New' 650
Post by sparki » Fri Jan 14, 2011 10:22 am
change the seal rather than butchering summink else ;)
KOCUK - 241
Cold Snail
Re: My 'New' 650
Post by Cold Snail » Sun Jan 16, 2011 2:13 pm
First of all, many thanks to Waltfen for the inlet rubbers.
I think I may have found the reason it was a pig to start (and only ran on 2 or 3, ending on one pot at the end).
There's a couple of rounded off screws to get two float bowls off, but I can't get to my tools without unloading the entire garage, so I'll get Andy (bolty on this forum) to have a go.
The tank's empty and I think is now clear, but I will add a inline filter when it goes back together.
I have also bought some genuine Suzuki seals and a pair of gaiters to do next week.
Cold Snail
Re: My 'New' 650
Post by Cold Snail » Sun Jan 16, 2011 9:36 pm
I think I know why it never ran on #2 :lol:
After an evening in the loft and a workmate, hammer and screwdriver attachments, I've got the tops and bottoms off. It's a shame I can't get the pilot jets out, but I need to find an 'in-between' screwdriver from my current selection.
Oh and 32 new screws :D
Re: My 'New' 650
Post by fossie » Sun Jan 16, 2011 9:42 pm
I've got to see andy at NRP in the week to get new float valves and jets for this 650 I got from Mark. Should I get you some ? Normally £45 ish full set , Saves doing job twice or more,
By the way on the bay at the mo are a set of GSX 400f clocks for £10 or so in Shaftsbury. They are the same as 650 except for white instead of red needles.
Cold Snail
Re: My 'New' 650
Post by Cold Snail » Sun Jan 16, 2011 9:48 pm
I'll have a crack with cleaning these, but I might need some pilot jets if they chew themselves up, the rest doesn't look that bad and should be OK once I've buzzed some carb cleaner through them.
