there is always one .................
Post by callyboy » Sun Jul 24, 2011 3:16 pm
frigging nut or bolt that wont frigging budge :roll: :roll: :roll:
The 2 broken exhaust studs that i have put off trying to get out were getting on my nerves whilst trying to clean the engine today. So, armed with a blowtorch some wax and my trusty molegrips i set about attacking them. Having skirted them with oil everytime i could remember when in the garage i laughingly assumed they would just fall out when threatened with my motley collection of tools.
Broken stud number 1 had a fair amount of length on it and i could get plenty of grip on it. heated it up and used a trick i saw on youtube of using some wax on it when hot. apparently the oil in the wax is drawn into the threads and helps. Hurrah ! After a few twists back and forth the mother started moving. Little did i know this was just a trick to lull me into a false sense of acheivment :(
The second stud is a lot shorter in length and my molegrips didnt get much of a purchase on it. Not sure where to go with this one. Was thinking of hacksawing a slot in the top to get a screwdriver on, but i reckon the stud is so tight in htere that it wont budge with a screwdriver.
Any suggestions ? the stud is sticking out about a quarter of an inch.
Have'nt i been here before ???????
Thanks in advance
Re: there is always one .................
Post by callyboy » Sun Jul 24, 2011 6:51 pm
What i need is a fugging welder !!! weld a nut on and hey presto !!!
Why is it always the fugging exhaust bolts that snap :(
Pete - fed up :(
Post by johnr » Sun Jul 24, 2011 9:31 pm
What you need is a fugging welder !!! weld a nut on and hey presto!!
oh right, you already said that.
what you need is a welder you know!
superfly
Post by superfly » Mon Jul 25, 2011 10:08 am
yeah just weld a not on it and of you go.
The question is do you have a welder?
superfly
Post by superfly » Mon Jul 25, 2011 10:09 am
you could also drill the stud and thread the hole and screw a bolt on.
Hope it helps pete.
Post by callyboy » Mon Jul 25, 2011 10:12 am
Cheers Arnaud, No dont have a welder :( I was going to try and drill it and use a extractor, but i have a feeling that my karma level is a bit low :( have bitten the bullet and bunged the engine in the Previa and taken it to my mate Russ at the bike shop. He takes pity on me :)
KatRider
Post by KatRider » Tue Jul 26, 2011 1:17 pm
your best tool for this are 'Irwin Stud Extractors'
awesome tools, they're like a socket set that has an inverse thread on the inside of the socket, and works similar to an easy out
Post by callyboy » Tue Jul 26, 2011 2:48 pm
Cheers Katrider. That looks interesting. bit cheaper than a welding machine so i will give that a go next time it happens.
KatRider
Post by KatRider » Tue Jul 26, 2011 8:53 pm
They're awesome I have to say..... Didn't help me tho when one of mine sheared flat with the head. There was nothing sticking out to grip on to.
A Drill on low speed then the use of an easy-out was my only saviour
Post by bobster » Tue Jul 26, 2011 10:53 pm
That is until you snap the easy out........in the drilled hole!
And then the only way to get it out is spark erode the thing as they're harder than a Millwall fan on Crack C0caine!
