airfilterbox popup kat
right,,, does anyone know how to get the standard airfilterbox in and out of the popup kat?
that is in one piece..
GSX1100SZ, GSX750SF, GSXR1100, GSX750SE popup special
Re: airfilterbox popup kat
I think it will only come out when you take the engine out............So has to go back in the frame before you put the engine back in!
I await to be corrected tho!
Pop-Kat
No correction needed, your quite right Rob, engine out to get the airbox in or out.
Engine out? wow not very smart of suzuki to do it like that.bobster wrote:I think it will only come out when you take the engine out............So has to go back in the frame before you put the engine back in!
Could not find anything about it in the workshop manual.
Maybe I will try to move the engine foreward a bit and take the intakerubbers off to get some room...
I hope that someone has a better idea then taking the engine out of the frame...
At least with the 400 one frame rail unbolts, damn pop up doesn't & that engine is one of the tightest fitting engines going....
Good luck with getting the bitch out
KOCUK 046 Jez
to be continued
to be continued
- lomsavage
- Has thanked: 3 times
- Been thanked: 28 times
just a quick question,
why does it need to come out ??
the answer to that could solve the problem
H
H
Hello from H
- Katgeezer
- Has thanked: 6 times
- Been thanked: 8 times
Even moving the engine forward doesn't give enough room, it really is an engine out job and as said it's a really tight fit as well, one of the most difficult engines I've ever removed.
