theoretical question at this stage
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Post by lomsavage » Thu Jun 09, 2011 11:44 pm
hi guys
just asking opinions for now
for the 1327 lump which would be better
dyna s or dyna 2000 ignition,
and if using either would it be better to fit their hi output coils as well
all opinions welcome
thanks
H
Hello from H
Re: theoretical question at this stage
Post by bobster » Fri Jun 10, 2011 6:39 am
You know my views on Dyna stuff.....................
lomsavage
Post by lomsavage » Fri Jun 10, 2011 10:58 am
yep,
loads of wd 40
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Hello from H
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Post by Katgeezer » Fri Jun 10, 2011 1:38 pm
You don't have to use dyna coils with dyna ignition systems. I've got some Andrews coils for my big'un, but, they're physically bigger than dyna's so I'll have to be imaginative with placement.
Basically you're getting a bigger spark as you're talking 30kV or even 40kV I believe with some rather than 18-20kV with std ignition so it can't be a bad thing. More efficient burn/bang gives more power surely so every little helps.
As to which one,well I think the 2000 is the newer model isn't it so it'll have the benefit of newer technology one would hope.
What I do know is that they're quite easy to fit and definitely an improvement over stock.
Post by johnr » Fri Jun 10, 2011 7:56 pm
dyna s is simpler, but the 2000 will allow you to set the redline on its adjustable rev limiter. so it depends if you are often missing gears!!!
DEANOTEK
Been thanked: 1 time
Post by DEANOTEK » Fri Jun 10, 2011 8:23 pm
Go for the Dyna 2000, i've been running it on the Kat1428cc turbo with no problems, also as JR stated, it has the added benefit of the built in rev limiter,... u dont want to drop a valve if u miss a gear,...we've all missed a gear at some point :roll:
All the best deanotek.
Post by johnr » Sat Jun 11, 2011 11:06 am
and if you park it somewhere dodgy you just flick the rev limiter to minimum and anyone who nicks it will only be able to rev it to 2000rpm!!!
DEANOTEK
Post by DEANOTEK » Sat Jun 11, 2011 12:39 pm
HA HA.... Yes... done that a few times, just make sure u can get your finger in to adjust it. ;)
