Carburettor x?!x!xcffffff
Berti44
Has thanked: 5 times
Been thanked: 21 times
Post by Berti44 » Fri Jul 08, 2022 3:08 pm
Any way to sync the carbs without removing the inlet screws? If not where do I buy the adapter. Why the xxxx didn’t remove those rusty crap screws when the engine was out of the bike.
Any advice welcome.
Cheers.
Berti44
Re: Carburettor x?!x!xcffffff
Post by Berti44 » Fri Jul 08, 2022 6:22 pm
Going to order a carb repair kit. Am I right in saying gsx750es 1983 will do the job.
Been thanked: 77 times
Post by Lexdba » Fri Jul 08, 2022 6:56 pm
Which bike? Which carbs?
If 1100 you only need to remove the allen bolts from the head…
Adapters come in most of the synchro kits.
Has thanked: 120 times
Post by Kryten » Fri Jul 08, 2022 7:06 pm
It's a Pop Up. So ES kit should do it.
Morgan Carbtune used to do a remote kit to install onto the bike permanently (well as permanently as you probably want to if you were keeping the bike and regularly balanced the carbs) but they have stopped selling it and just tell you how to do it yerself :lol: :lol:
http://www.carbtune.co.uk/carbaccs.html
Berti44
Post by Berti44 » Sun Jul 10, 2022 9:12 am
Thanks for the replies. BS34SS standard carbs on my pop up. I’ve ordered the ES repair kit Kryten and some vacuum adapters off flea bay. Already got vacuum gauges from tuning my short stroke engine Gixxer Slingshit.
Best wishes.
Been thanked: 716 times
Post by fossie » Sun Jul 17, 2022 12:08 pm
Btw the rap rusty screws that chew up are because you are using a normal screwdriver probably and not a jap motor industry head.....yep we didn't know until a few years ago either ;)
Post by Smallkat » Mon Jul 18, 2022 11:01 am
Yes, best thing you can buy is a good quality JIS screwdriver set. I've had Japanese bikes my whole life, worked in the motorcycle industry since 1996 and I only found out about this screw type a few years ago!
