Popup carb inlet rubbers
Re: Popup carb inlet rubbers
Post by Uncle Bob » Wed Jun 29, 2022 7:00 am
I use a ratchet strap to help ease mine in (with help from some rubber grease on the inlets), holds them in place and you can push in one end without the other popping out. Image below is from my 250 but just used the same process on my 1100 (twice as after cleaning the pilot jets I had to take off again to replace the needle valves - why didn't I bench test!)
Berti44
Has thanked: 5 times
Been thanked: 21 times
Post by Berti44 » Wed Jun 29, 2022 5:36 pm
What an ingenious idea. I might end up trying it the weekend thanks for sharing.
Post by Smallkat » Fri Jul 01, 2022 5:26 pm
Also silicone spray like Silkolene Pro Prep can help them slip on.
Berti44
Post by Berti44 » Sat Jul 02, 2022 7:47 pm
Cheers to all for the advice, finally now in place. 👍
