pop-up wire electrics.
jmac
Been thanked: 84 times
Post by jmac » Fri May 28, 2021 9:52 pm
my pop-up is back on the road, but with one teeny-weeny problem. no neutral light. I've traced the blue wire from the sender on the o/side through to near the fuse box are where it ends in a bare wire just flapping in the wind. The diagram says it goes to the neutral light switch but doesn't show where said switch is located. Constructive comments would be welcome.
jmac
Re: pop-up wire electrics.
Post by jmac » Fri May 28, 2021 9:55 pm
should read "fuse box area", apologies.
Post by Smallkat » Fri May 28, 2021 9:56 pm
neutral switches are normally located on the end of the shift drum on old Suzukis.
Post by Kryten » Sat May 29, 2021 1:56 pm
Yep! Just by the front sprocket to catch all the lube and road dirt :lol: :lol:
jmac
Post by jmac » Sat May 29, 2021 10:16 pm
As Tommy Cooper once said Thank you very much.
