Leaky brake caliper
Re: Leaky brake caliper
Well that's the panic over! I used the large syringe up the bottom (ooer missus) and managed to get the air out. Brakes are as good as ever (Shite lol) just need to sort the mounting bracket now which hopefully Jim Kryten has got for me. Looking forward to some summer rides out now.
- Has thanked: 128 times
- Been thanked: 269 times
Just been reading your post regarding bubbles. I have found when using the vac pump that if there is a bit of play in the bleed nipples then the pump will draw air down the threads and it appears that the system is full of air.
I have had to put a couple of wraps of PTFE tape on the Speed Trips nipples
Yep I think that was the problem Jim, although I did wrap my nipples with ptfe fnarr fnarrKryten wrote: ↑Mon Mar 29, 2021 5:52 pmJust been reading your post regarding bubbles. I have found when using the vac pump that if there is a bit of play in the bleed nipples then the pump will draw air down the threads and it appears that the system is full of air.
I have had to put a couple of wraps of PTFE tape on the Speed Trips nipples![]()
The old giant syringe up the bottom made all the difference
PaulD wrote: ↑Mon Mar 29, 2021 7:16 pmYep I think that was the problem Jim, although I did wrap my nipples with ptfe fnarr fnarrKryten wrote: ↑Mon Mar 29, 2021 5:52 pmJust been reading your post regarding bubbles. I have found when using the vac pump that if there is a bit of play in the bleed nipples then the pump will draw air down the threads and it appears that the system is full of air.
it didn't make much difference.
The old giant syringe up the bottom made all the difference![]()
Bit off topic, but for anyone who grew up in the seventies, why did the readers wives in mags like razzle have electrical tape over their nipples? and blindfolds?
Blindfolds
weren't the blindfolds so you didn't recognise the woman next door?
I don't remember tape over the nipples, but I do have a Japanese jazz mag that has the privates censored! A souvenir from my visit to Tokyo.
Well thanks to Jim (Kryton) I've got a caliper bracket. Unfortunately Beelzebitch refused point blank to wear it until it was cleaned and painted
I set to this morning, bead blasted and give it a coat of gloss black. Just give it a second coat so I'll fit it tomorrow.
Thanks Jim your a star
you
I knew you'd get it sorted. I did check threads and they were good.PaulD wrote: ↑Wed Mar 31, 2021 3:49 pmWell thanks to Jim (Kryton) I've got a caliper bracket. Unfortunately Beelzebitch refused point blank to wear it until it was cleaned and paintedI set to this morning, bead blasted and give it a coat of gloss black. Just give it a second coat so I'll fit it tomorrow.
Thanks Jim your a staryou
If you think that was tatty then you should see the master cylinder that I have just off loaded to a North Norfolk club member.
