it's a Suzuki GSX250F Across, in many bits. Red lined at 16500 rpm. Fuel tank under the seat has an electronic filler cap flap operated by a separate key position on the ignition switch. The dummy tank at the front is a storage bin, again operated electronically, that can accommodate a full face helmet with ease. Worryingly, the carbs are also electronically controlled.............
Note to self - don't bid under the influence of alcohol........................
