Front Wheel Differences: 1100S vs ET
jeznewsome
Post by jeznewsome » Tue Mar 31, 2020 5:41 pm
The front wheel on my 1100 is powder coated and doesn't look right! I have bought a 1100ET front wheel which has the same spoke pattern but the the hubs centre looks different
1100S Centre (left hand side is different from the right)
ImageDSC_2171 by jeznewsome, on Flickr
1100ET Centre
ImageDSC_2172 by jeznewsome, on Flickr
Anyone know why this is, both are the same manufacturer - Enkei and size 19 x 1.85?
Re: Front Wheel Differences: 1100S vs ET
Post by johnr » Thu May 07, 2020 12:22 am
Some american market GS and gsx models came with a single front disk. Possible your et wheel came from one of these? Is it the snowflake spoke pattern? If you wanted one, you should have asked, I've a pile of them, I'm planning to use them as a trellis for my climbers!
Post by fossie » Thu May 07, 2020 7:11 am
It could even be a 650/550 wheel. All mine look like that .
Could even be as simple as cast in different factories.....but then it could be that the 1100 power output was considered to require a chunkier brace.
As always when buying 2nd hand a risk is involved, I mean the seller might not have known ...we didn't / don't! :shock:
A Suzuki part number check will say wether the 1100 SZ and ET Models were the same.
jeznewsome
Post by jeznewsome » Thu May 07, 2020 9:17 am
Its the same pattern, just a slightly different hub casting?
Cleaned up and painted yesterday the spokes yesterday. :D
Post by fossie » Thu May 07, 2020 10:15 am
It seems that at the beginning the Kat and the ET were different fitments , but at some point they were superseded and the ET type won out ...because it was used on the 650/550//750 aswell.
So either would be correct? :shock:
