It'll t cut out!
Been thanked: 716 times
It'll t cut out!
Post by fossie » Thu Oct 31, 2019 11:11 pm
Re: It'll t cut out!
Post by PaulD » Fri Nov 01, 2019 5:29 am
Carefully stored in the canal :lol:
Has thanked: 120 times
Post by Kryten » Fri Nov 01, 2019 10:26 am
Now that does look like it’s been used as a “Boat Anchor”!
Was trying to see what there was economically salvageable, but not sure if there is enough.
Frame still has an ID with DVLA so you could use it as a base for a special.
Engine.....
Carbs.....
Swing arm and rear wheel. Front end (although forks are Jolly Rogered) could help with a running gear up grade maybe.....
Or a very brave resto! :lol: :lol:
Post by Uncle Bob » Fri Nov 01, 2019 11:20 am
Unbelievable! Your boat anchor comment Kryten was just the thought I had!
Post by johnr » Sat Nov 02, 2019 3:30 pm
thats a brave restoration, but, its cheap enough. lets face it, if youre buying to restore, then youre likely to strip it to powdercoat and paint first anyhow, so its not that big a deal if its tatty. frame seems to be mostly surface rust, tanks has almost certainly had it, but stainless exhaust and metmachex swingarm are worth having. engine is only a 750 so its more than likely bin fodder anyhow. ive seen folks pay more for a lot less.
Post by Kryten » Sat Nov 02, 2019 5:41 pm
Shhhh! Don’t say anything but.....
......somebody has bid on it!
....and it’s not me :lol:
Post by Kryten » Sat Nov 02, 2019 7:43 pm
....and gone!
Post by johnr » Sat Nov 02, 2019 11:38 pm
so who bought it? anyone here?
