And so it begins!
Re: And so it begins!
Carbs on, airbox and plenum chamber fitted. Just the exhaust to fit, fill it with flush oil and spin it over without the plugs fitted to see if there’s oil getting to the top end (hence the cambox cover missing) and I’m good to go. Getting nervous now and it’s going to take some courage to press the button with everything connected up
It lives
Everything back together and she fired up first time on the button!
I’ve fitted the Jama 4-1 for the time being as it’s a LOT easier to fit than the standard 4-2 zorst and I want to take the sump plate off to check all is ok inside and no more bath sealant appears inside
Gotta balance the carbs yet but she seems a lot quieter and less smokey than before. Fingers crossed
I’m just debating weather to leave the Jama on it or put the standard (bloody heavy) exhaust back on it. What do you think people?
Mmmm I’ve tried to up load a video but it comes up with an error
Invalid file extension: 7EA937D4-2C2B-42E6-BDDC-EFA3F6E8FBBF.MOV
I’m thinking the same tbh plus the Jama is quiet which I like (I’m old now
It weighs less than half the standard system which helps with me being a short arsed arthritic, 11 1/2st pensioner
Poppy & big sister Pussy enjoying the evening sunshine
Thanks Sam but I haven’t got a clue what that is
I just filmed the bike using my iPhone camera.
- Has thanked: 660 times
- Been thanked: 250 times
Oooooo! I got such grief from Fossie when I said I'd done the same... (though I also prefer the 4 into 1 Eagle on the bike anyway)
Just waiting for him to notice you and Paul doing the same...
- Has thanked: 187 times
- Been thanked: 738 times
So wrap up the expensive one so the next owner ( which should never be ...a Kat is for life) can be stored until it succumbs to the vagrates of time.
Now there's a plan.....
Just saying!
Well I hate 4-1 zorsts
The plan is to ride the feckker as all I’ve done since adopting it is throw money at putting past owners cock ups/lack of care right.
Oh and I think the original exhaust will be going back on at some point in the near future, did I mention I hate 4-1 zorsts
Well I've had the spanners out again this afternoon
it's ok though as I've just dropped the cheepo oil after running it gently for about 50miles. I've had the sump and internal filter off to check for any remains of bathroom silicon & metallic nastys which thankfully there wasn't. A new hi flow filter and fresh Rock Oil mineral finished the job off. The remaining jobs are balancing the carbs, re-torque the head after 500miles and check the valve clearances.
