I'm Stumped! Shorter front forks on 1100 help required
Re: I'm Stumped! Shorter front forks on 1100 help required
Post by Uncle Bob » Thu Apr 04, 2019 6:55 pm
stockcar wrote:Mine was done with no weight over the front.....
Cheers again Stockcar! That is probably enough really and means I have another set of forks to take a part. I think I know why they are about 46cm instead of 43.5cm, but I'm not going to admit to anything until I check them out first (and even then I don't think I'll admit anything!). I'll get the Swiss Katana ones back together first, but that will have to wait until end of next week as away for a bit.
jeznewsome
Post by jeznewsome » Fri Apr 05, 2019 11:49 am
I'll check mine later.......
Post by PaulD » Sat Apr 06, 2019 8:30 am
Ok, I’ve checked mine and as close as I can see they are 43.5cm with the back wheel weighted down.
Hope this helps?
jeznewsome
Post by jeznewsome » Sun Apr 07, 2019 4:30 pm
Sorry but my measurement was with the dust boots still on but hopefully the photo below will give you an idea.
Image2019-04-07_05-27-32 by jeznewsome, on Flickr
Been thanked: 119 times
Post by katmarch » Sun Apr 07, 2019 7:41 pm
Not sure if this will help, but my readings are :-
Spare front end, guess these are ET's
Mine, believe they are ESD, adjustable damping at bottom of leg
And my short ass set
All measured from the top of the leg
