fuel tap / tank
- fat nick
- Has thanked: 69 times
- Been thanked: 33 times
fuel tap / tank
Just a quick check .. am I right in assuming ( yes that word) that, there is no difference in 750/100/1100 fuel tank hence fuel taps ?? Robinsons seem to quote same P/N for Taps for all models ?? As I am told my Kat 750 was an import ( captive bolts for front engine mounts ) is this the same ?? thanx for any light you can shed on this
KOC 291
Re: fuel tap / tank
theyre all imports!
captive bolts for front mounts indicates its an sd frame as the earlier sz's have the bolt going through the frame with a nut on the other side, sd's have a captive threaded insert that th bolt screws into. but, yes, fuel taps are all the same!
- Been thanked: 715 times
Re: fuel tap / tank
Yep I got a couple of fuel taps from eBay for the 250 and pop up , both less than £15 each Just put in Suzuki GS Fuel tap, they look like the older ones but fit and work.
