Valve stem seals
Valve stem seals
I’m going to replace the valve stem seals when I do a top end overhaul this winter. I’ve noticed grumpy1260 sells super duper Viton seals and was wondering if these are ok or should I go mad and buy gen Suzuki? I’m trying to keep the wallet damage to a minimum
- spondonchris
- Has thanked: 18 times
- Been thanked: 18 times
Re: Valve stem seals
Thanks Chrisspondonchris wrote:I would recommend genuine
- fetishkat
- Has thanked: 255 times
- Been thanked: 17 times
If you’re looking at keeping the bike long term go genuine, after market should last a few years but will give up a lot sooner. Racing seals only need to last a season.
- Been thanked: 343 times
no, get gen valve stem seals. the viton ones are advertised as 'racing seals' which means that whilst they can cope with super high temps, they will only last a couple of seasons before they need replacing as race engines get stripped a couple of times a year. genuine seals are the best bet, also gen clutch plates are the best too.
Thanks guys, genuine Suzuki it is
