do reg/rectifiers do get hot in use?
Re: do reg/rectifiers do get hot in use?
Post by callyboy » Wed Nov 25, 2015 9:16 pm
quite a few peeps seem to mount them under seats in a tray nowadays. They dont seem to have many problems, although some kind of air flow would be nice eh? maybe rig up a bit of ducting?
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Wed Nov 25, 2015 9:58 pm
Had mine fitted underseat on a tray for 6+ years now no problems.
It is an Electrex one though not an original and I`ve mounted it on raised bolts not flush to the tray to help with cooling. ;)
As Pete said plenty of people have done this and I`ve not heard of any probs.
If you are concerned with heat you could always mount it on the underside of the tray.
Post by Uncle Bob » Thu Nov 26, 2015 6:03 pm
As it's an alloy tray get some thermal paste (as used on CPUs in a computer) and use the alloy tray as a large heatsink!
Soichiro
Post by Soichiro » Thu Nov 26, 2015 6:37 pm
Otherwise known as heatsink compound. Available from Maplin, RS etc.
GS650G - Biggest pile of crap on the planet
400FOUR (F2 in Candy Antares Red)
Post by johnr » Thu Nov 26, 2015 10:00 pm
katanamangler has a 12v computer panel fan bolted to his to air cool it! but wherever the reg rec is, make sure it gets earthed properly right back to the battery because poor earthing makes them work harder and when they work hard, they get hot.
Has thanked: 80 times
Been thanked: 72 times
Post by sparki » Mon Dec 14, 2015 3:39 pm
an absolute must is avoid the bar switch like you say. worst idea ever that was...
KOCUK - 241
Soichiro
Post by Soichiro » Mon Dec 14, 2015 5:25 pm
Why's that then? Is it too much power going through the switch contacts. My GS850 was wired the same and that didn't suffer at all.
Post by johnr » Mon Dec 14, 2015 9:50 pm
the idea was to route 2 phases to the reg rec and thus to the battery, then wire the third phase to the reg rec vis the light switch so that when you put the lights on the battery got more power. sounds great in theory, except that the reg rec struggled with the imbalance of 2 phases running flat out and one not being able to get rid of its power because it was switched off. couple this with low oil levels making engines run slightly hotter, but hot enough to overheat the windings of the generator. always a bad idea and they started to fail almost from new. best thing to do is what everyone else does, put all 3 phases through the reg rec and let that sort out charging the battery and dumping the excess charge by means of creating heat. its a pointless exercise. and they dont suffer from having the 3 phases run direct to the reg rec.
Soichiro
Post by Soichiro » Mon Dec 14, 2015 10:16 pm
I got the 'switch in an extra phase to power the lights' idea but I didn't realise it had an adverse effect. In that case, a bit of rewiring is called for.
