550 charging system
Re: 550 charging system
i have a 550 speedo and rev counter holder thing with just the rev counter and centre light cluster Nicky. any good?
- Nicky Dodds
- Has thanked: 143 times
- Been thanked: 45 times
Thanks for the offer pete but i've had both the clocks to bits and changed the needles, replaced all the shot bulbs in the gear indicator and got the speedo working again which in reality was just bent tangs in the drive.
Kill switch is wrecked and bypassed and pass switch has stopped working which i've not investigated yet. Both mirror mounts are u/s and need replacing. Otherwise the cockpit area is good, got some new cut down renthals and new grips on.
- Nicky Dodds
Meter arrived!
Looks like it's written in egyptian!!!
Only setting you need are the buzzy thing and the 12 volt thing
what one you got? will tell you where to set it.
- Nicky Dodds
Excel XL830L
Big dial in middle, back light button, hold button, that's about it...
red bit at 5 o'clock is the buzzy thing
top left voltage set to 20 is the volt thing
simples
simples
- Been thanked: 343 times
dont buy a cheap crimper. buy a ratchet crimper. theyre not stupidly expensive, but not dirt cheap either. but you will own it forever.
- Nicky Dodds
Getting 13.5 when running at 2000rpm
Loads of ratchet crimpers on ebay, any particular ones to avoid john ?
- Nicky Dodds
Pete what did you have your air screws set at when you had your 550 ?
