Ignition timing mark, 1100 Kat
JACKJABBA
Post by JACKJABBA » Sat Apr 16, 2011 5:13 pm
In the manual I have, it refers to a "T" mark on the ignition timing rotor, mine does not have that style of rotor, it just has a piece sticking out from the shaft that the pickups detect. Is this normal for the 1100 Katana, and do you still set it to the mid point on the left hand pickup for setting the valve timing?
Regards Jack
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
Been thanked: 198 times
Re: Ignition timing mark, 1100 Kat
Post by Pedda » Sat Apr 16, 2011 6:26 pm
Your ignition advancer should look like this:
You can see the relevant marks on it, includet the T.
You also should find this part:
You see the mark at the top? This is where the T of the advancer should refer to.
JACKJABBA
Post by JACKJABBA » Sat Apr 16, 2011 7:20 pm
Thanks Peda
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
