Taliban bus question for Fossie
Post by callyboy » Sat Oct 25, 2014 5:08 pm
Whats the yellow can with a wave underneath it on the warning panel? Water level looks ok. I assume red can is oil?
Been thanked: 715 times
Re: Taliban bus question for Fossie
Post by fossie » Sat Oct 25, 2014 5:59 pm
Yellow can with wave On the right side of dashboard is oil . Can mean over full or under full If it comes on intermittently it needs an oil change. Which should be done every 6000 Km's butI do mine every 6000 miles.
The oil pressure is red on left side of dashboard.
Orange = check. Red = too late!
Water level is next to wavy oil can and is supposed to be a radiator. But looks more like a carousel :?
Post by callyboy » Sat Oct 25, 2014 6:21 pm
Cheers Fossie. Seems to come on now and again. Usually when going up hill. Think mot is due so will get them to do an oil change for me anyway.
Post by fossie » Sat Oct 25, 2014 6:32 pm
If it comes on up hill could be level , best check it.
I assume you know where the dip sick is. ..but just in case lift passenger seat by un clipping the yellow knob. When seat is released slide seat forward on runners so it is all way forward then tilt seat up out of way. Under the carpet is a panel with 2 wing nut things 1/2 turn releases them remove panel, 2 dipsticks , black oil level , red is auto transmission , just check it aswell anyway while you there.
Post by fossie » Sat Oct 25, 2014 6:39 pm
Whoops sorry you must know you had a previa before this.
Post by callyboy » Sat Oct 25, 2014 6:43 pm
yeah :) Will check. ta.
