b12 motor into 750 kat frame advise
B2BC
Post by B2BC » Mon May 26, 2014 3:10 pm
hi im currently dismantling my efe/b12 and transferring it into a 1982 750 kat frame does anyone have any diagrams/drawings of engine mounts ect
im wondering if the mounts on kat frame are same as my efe dont want to drop engine out of efe just yet unto kat frame is ready for powdercoating, will be using a stripped b6 motor as rough idea for engine not much difference between them.
been told efe lump drop straight into kat frame??? so going of that , im guessing all the mounts i made for b12 engine to fit into efe should be the same and bolt onto kat frame???
bikes dont leak oil, They mark there territory
Been thanked: 198 times
Re: b12 motor into 750 kat frame advise
Post by Pedda » Mon May 26, 2014 4:39 pm
EFE lumps fit right into a Kat frame - with Kat mountin plates. That does not necessarily mean that EFE mounting plates must fit, obviously, but worth a try.
I have some sketches of plates, but you just need to have a closer look at the lower ones as I can't tell if these are for 7.5 or 11 frames.
<a href="http://s121.photobucket.com/user/Pedda_ ... 1.jpg.html" target="_blank"><img src="http://i121.photobucket.com/albums/o201 ... 01/001.jpg" border="0" alt=" photo 001.jpg"/></a>
<a href="http://s121.photobucket.com/user/Pedda_ ... 2.jpg.html" target="_blank"><img src="http://i121.photobucket.com/albums/o201 ... 01/002.jpg" border="0" alt=" photo 002.jpg"/></a>
Ah, here's the 7.5 frame lower. And the adaptor you'll need between headers and head
<a href="http://s121.photobucket.com/user/Pedda_ ... 3.jpg.html" target="_blank"><img src="http://i121.photobucket.com/albums/o201 ... 01/003.jpg" border="0" alt=" photo 003.jpg"/></a>
Post by Pedda » Mon May 26, 2014 4:41 pm
Hmh, my compy skills have seen better days...
http://i121.photobucket.com/albums/o201 ... 01/001.jpg" onclick="window.open(this.href);return false;
http://i121.photobucket.com/albums/o201 ... 01/002.jpg" onclick="window.open(this.href);return false;
http://i121.photobucket.com/albums/o201 ... 01/003.jpg" onclick="window.open(this.href);return false;
Here's a complete set:
http://s121.photobucket.com/user/Pedda_ ... 4.jpg.html" onclick="window.open(this.href);return false;
Post by Pedda » Mon May 26, 2014 4:42 pm
Can't seem to post piccies any more, just links.
B2BC
Post by B2BC » Mon May 26, 2014 6:14 pm
looking at the mounts i have of efe to use a b12 motor ,most the dimesions are the same apart from front two, lower rear ill weld mounts inplace
