Pop up shock advice
Re: Pop up shock advice
Post by callyboy » Sat Dec 28, 2013 8:49 pm
http://www.katanaownersclub.co.uk/forum ... =28&t=5214" onclick="window.open(this.href);return false;
Pop-Kat
Post by Pop-Kat » Sat Dec 28, 2013 11:59 pm
It's not a rebound dial, it's for pre load and probably doesn't work any more. when you fit another shock cut the preload hose at the shock end and cable tie it out the way, you'll keep the look then.. as for a new shock your best bet is a Hagon, you'll get one for £300.
