Motobatt Gel Battery
Post by Uncle Bob » Wed Aug 21, 2013 8:36 am
Anyone got any experience of Motobatt Gel Battery replacements. Saw another post for another make that seemed to suggest Gel ones were OK, just wondered about this brand and a good price here on ebay.
http://www.ebay.co.uk/itm/150908782954? ... 1438.l2649
Cam
Has thanked: 2 times
Been thanked: 5 times
Re: Motobatt Gel Battery
Post by Cam » Wed Aug 21, 2013 9:18 am
I bought one only recently haven't used it on the road yet as I'm still building but it turned my engine over a lot better than before and in running a 1500cc big block with 11:1 compression
Has thanked: 120 times
Post by Kryten » Wed Aug 21, 2013 9:48 am
Using one on my Speedtrip
Seems to be doing fine
Think I got it from Wemoto
Had a different one on the Kat but it is not charging very well my Optimate keeps saying that it will not hold a charge
But that might be due to it standing for a while unused :oops:
Has thanked: 80 times
Been thanked: 72 times
Post by sparki » Wed Aug 21, 2013 11:36 am
don't think an optimate is meant to be used on those are they?
KOCUK - 241
Post by johnr » Wed Aug 21, 2013 3:31 pm
i only use motobatt batteries on my bikes now.
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Post by Katgeezer » Wed Aug 21, 2013 8:14 pm
Was it these ones or another brand that suffer from cheap knockoffs ?? Buy from a trusted source I guess.
Post by Kryten » Wed Aug 21, 2013 8:33 pm
sparki wrote:don't think an optimate is meant to be used on those are they?
Optimate 3+ are OK for AGM and gel batteries
Post by Uncle Bob » Fri Aug 23, 2013 9:00 pm
Cheers for all advice - I'll get one as I hate having to get the battery out just for top up - last time I think it needed so much it's mostly watyer now!
Optimate 3 are good for Gel batteries (use on my VStrom and SV650 before that). Infact if you have one, I think you are better using an Optimate as if left for while (esp. over winter) I have found even fairly new Gel ones will not hold charge anymore and you'll have to replace.
Post by johnr » Sun Aug 25, 2013 3:20 pm
if your battery is losing acid then it may be boiling dry. have you checked the chaging voltage with a multimeter at all?
