1100 STARTING ISSUES
leedsutdafc
Has thanked: 2 times
Been thanked: 4 times
Post by leedsutdafc » Sun Jun 02, 2013 5:34 pm
Tried the 1100 for the first time today for a while .The carbs were empty so spent a couple of mins on prime etc.No joy so left it for ten mins .Went back outside pressed starter just click battery is charged again still just click when I hit starter any other ideas ?
K.O.C 358
Katana 1000/1100
Katana 650
Katana 1000 mk2
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Re: 1100 STARTING ISSUES
Post by Katgeezer » Sun Jun 02, 2013 7:06 pm
Did the engine turn over THEN the battery went flat? Or did you not try because you felt there was no fuel at the carbs?
Sorry just trying to get a feel for the course of events.
Post by callyboy » Sun Jun 02, 2013 7:16 pm
stick a volt meter on the battery and see what its holding.
leedsutdafc
Post by leedsutdafc » Mon Jun 03, 2013 2:14 pm
Battery sounded fine I just left it for ten .battery fully charged wont bump off engine did turn over in the original attempt..
K.O.C 358
Katana 1000/1100
Katana 650
Katana 1000 mk2
leedsutdafc
Post by leedsutdafc » Mon Jun 10, 2013 5:43 pm
Fitted new battery still just click when hitting starter button .All lights etc are ok just nothing from starter.
K.O.C 358
Katana 1000/1100
Katana 650
Katana 1000 mk2
Pop-Kat
Post by Pop-Kat » Mon Jun 10, 2013 6:56 pm
Starter motor
Post by bobster » Mon Jun 10, 2013 9:32 pm
Make sure you havnt filled the cylinders with fuel when you left it on prime !!! and locked the motor up with fuel !!!!
Take the plugs out and see if the engine will turn over by using a spanner on the nut on the R/hand side of the crank! Also check the oil level in the engine...............and sniff the oil in the engine to see if it smells of Fuel.
