550 Dimension please
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Fri Feb 22, 2013 10:47 pm
Hi 550 owners. If you have seen my Café Kat project you may of noticed that there are no seat locating brackets on the frame top rails.
The frame was generally pretty cut up and dubious bits added before I got hold of it.
What I need is the dimension from the centre of the rear tank mounting holes to the back of the locating brackets on the frame top rail.
Many thanks
Nigel
Nigelkat
Has thanked: 1 time
Re: 550 Dimension please
Post by Nigelkat » Sat Mar 02, 2013 9:49 pm
Bump
any 550 owners poping out to the garage this weekend
Post by callyboy » Sat Mar 02, 2013 9:53 pm
Ooops. Sorry Nigel. Forgot. Will have a look tommoz when i can.
Post by callyboy » Sun Mar 03, 2013 1:45 pm
50 from centre of bolt to back of plate.OK?
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Sun Mar 03, 2013 9:32 pm
Opps sorry Pete not that one its the 1 in the pic below
Nigel
Post by callyboy » Sun Mar 03, 2013 9:53 pm
:) ok. Tomoz.
Post by callyboy » Mon Mar 04, 2013 2:50 pm
2cm (is that right? mm are ther little buggers right?) :oops:
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Mon Mar 04, 2013 8:41 pm
Cheers Pete, looks bout right. yeah mm are the little buggers that I can`t see anymore. old age and all that.
