Oil leak as well!!
Oil leak as well!!
Similar to the last post. My 1100 Kat is leaking at front of motor after a new rebuild. Head was skimmed,new gaskets all round,even retorqued the head,plus a bit. Is it possible for a exhaust stud to be over tighten and hit an oilway. Or possibly that m10 bolt at the front centre could be the culprit. Are they prone to weep. Thanks.
- Pedda
- Has thanked: 53 times
- Been thanked: 198 times
Re: Oil leak as well!!
M10 bolt? I suppose you mean the M6 then with that 10mm spanner width? There's no leak to be seen there, normally. That's only the point where the oil is collecting and dripping off.
Also: overtightening the exhaust studs won't do any harm to the oil ways. Before that you will destroy the threads.
Same first measurement like in the other thread: O-rings of the stud nuts.
FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Yeah. The oil runs forward along the second from bottom cooling fin. Then onto the cam chain centre little 6mm bolt making u think its the head gaskets leaking
Thanks everyone for your help. As I reused the old ones that may well be the cause.
Sorry,don't want to sound thick but,if the o rings are leaking,where is the oil getting out from to the front of the motor if it is above the head gasket.Thanks.
- Pedda
Wind and vibrations will make it that way. No wonder.
But we are only suggesting where to look first (and easiest to fix) which is the culprit in most of the times. At the end of the day you might find that it's the head gasket...
chris44
This is a bit spooky exactly the same thing happened to me before my hols. I took the cam cover off my G*X750 to have look at the chain and tensioner. GPZ9 tensioner in no rattle great! Oil everywhere not great! Least I know where to look now thanks chaps
