Engine cover decal removal
germankat
Post by germankat » Sun Jan 29, 2012 5:30 pm
Anyone know a good tip for removing the engine cover decals? I have the correct ones to go back on and I want to polish some scratches out of the genny cover but I can't get the old decals off.
Cheers, Adam :?
Re: Engine cover decal removal
Post by johnr » Sun Jan 29, 2012 6:39 pm
sharp woodworking chisel and great care! its tricky but the only way. getting it hot will loosen the adhesive, but theyre stuck on well!
germankat
Post by germankat » Sun Jan 29, 2012 7:20 pm
Cheers for that, I have already tried removing with a sharp impliment but not added the heat yet.
germankat
Post by germankat » Mon Jan 30, 2012 8:07 pm
right, top tip for these things, leave to soak over night in sticky stuff remover, and it comes away no probs.
Off to the polishers then.
jerry
Has thanked: 6 times
Been thanked: 8 times
Post by jerry » Tue Jan 31, 2012 4:43 pm
So.........having just taken crankcase cover in for weld on small underside crack ;) , the guy said to me 'you realise that because this is done at such a high temp' the decal will bubble up and fall off' Ha Ha I thought........ :D :D
Jerry
GSF 1200 K6 2006 Naked
germankat
Post by germankat » Tue Jan 31, 2012 7:37 pm
I've been doing polishing at home for years now, horrible job, got the quote back today for all 4 engine cases, £40................. why have I been bothering to do it at home? let you know how good the results and then maybe a recommendation of local services list?
Katman
Post by Katman » Tue Jan 31, 2012 8:22 pm
Where's that at?
You're only down the road from me
KOCUK 046 Jez
to be continued
germankat
Post by germankat » Fri Feb 03, 2012 12:49 pm
Hi Katman, the place is called Suussex Polishers or polishing, they are in Lancing. Haven't had the bits back yet so I am still not sure of how good the work is yet,but will let you know.
germankat
Post by germankat » Wed Feb 22, 2012 8:59 pm
Bits back, I'm happy to recommend the quality.
