Pop-Up oil lines
outrage
Pop-Up oil lines
Post by outrage » Fri Dec 09, 2011 9:48 pm
The oil lines at the back of the top end which run from the head to the crankcase seem to be excreting some oil (along with a few other places). Which direction does the oil flow through these lines. I cant seem to find a diagram anywhere.
uber pikey
Re: Pop-Up oil lines
Post by uber pikey » Fri Dec 09, 2011 9:56 pm
These are the pipes that feed the cams and jets so the flow is from bottom to top.
outrage
Post by outrage » Sat Dec 10, 2011 9:30 am
Muchas Gracias :) So if thats the case and mine are leaking slightly then thats really not a good thing.
Been thanked: 715 times
Post by fossie » Sat Dec 10, 2011 10:20 am
Mine always have , on both this one and my old ESD --------------they all do that sir!
uber pikey
Post by uber pikey » Wed Jan 25, 2012 11:39 am
Just to let you know that Pirtek are looking at my pipes tomorrow and will give me a price for replacements. Will let you know prices and whatever else I can badger them for.
I aim to price up a replacement(original as possible) and a goochy braided set for both front and rear hose sets, any questions you would like me to ask them put them on here.
Katfish
Been thanked: 29 times
Post by Katfish » Wed Jan 25, 2012 4:36 pm
I had mine sorted by pirtec, they removed the original rubber hose and replaced it with braided, but kept all the original steel pipes & it as been fine since. Cost me nothing as I use them for hydraulic pipes at work, so it was done as a favour :)
Andy...KOC 298
Snap, Crackle & Pop Up
uber pikey
Post by uber pikey » Thu Jan 26, 2012 6:06 pm
Update, I took the Kat over to pirtek and they have replaced my hoses with braid also and as you pointed out on yours katfish they used the old banjo adapters as m8 was a problem to sort. Anyhoo pipes fitted and braised all for £30. It was a bit of a ball ache but if anyone wants some made up for £35 inc postage let me know but you have to supply with your hoses.
outrage
Post by outrage » Sat Jan 28, 2012 9:01 am
Good to know. Will get around to it someday.
