KOC has new media whore
Has thanked: 80 times
Been thanked: 72 times
Re: KOC has new media whore
Post by sparki » Sun Dec 18, 2011 4:51 pm
Kryten wrote:Well I would read it first hand, but it no arrive through letterbox :(
yeah.. neither did mine arrive....
KOCUK - 241
Been thanked: 716 times
Post by fossie » Sun Dec 18, 2011 9:21 pm
With ref to me selling te bike in question , firstly it is now worth more as it is famous!!!! But you may also remember it's available because the other one has a newer engine and the 400 is good to go again, Also it's a limited offer to make space until I can find time and space to sort out the swapping heads. If it don't find a new home so be it i'll just extend the garage!
Post by fossie » Sun Dec 18, 2011 10:01 pm
Is the article any good ?I haven't actually read it, I will wait 'till wednesday and get it at the petrol station like I normally do.
Or should I hide my head in shame?................More than ususal.
FBJ
Has thanked: 5 times
Been thanked: 31 times
Post by FBJ » Sun Dec 18, 2011 10:11 pm
It's a good right up. Testimont to the kats
Has thanked: 120 times
Post by Kryten » Mon Dec 19, 2011 10:27 pm
...at last est arivee!
Keep your classic in a centrally heated garage?
As they say round here "That'l larn 'em"
Nice one, boss. :D :D
nokatanayet
Post by nokatanayet » Mon Dec 19, 2011 10:45 pm
way to go fossie ;)
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Post by Katgeezer » Tue Dec 20, 2011 12:41 pm
And as a footnote I see our 'regular' media whore is in this months Classic Mechanics with his new 1100E.
PS,well done boss,good piece.
Post by bobster » Tue Dec 20, 2011 12:55 pm
What do you use the 13mm spanner for Fossie? :?
Suzuki's dont use that size of bolt heads! ;)
Good read by the way!
Maybe if you did check the valve clearances every once and a while the engines would last even longer.............because the GS range of Suzuki's tended suffer from their valve clearances getting smaller. ;)
FBJ
Post by FBJ » Tue Dec 20, 2011 5:52 pm
bobster wrote:What do you use the 13mm spanner for Fossie? :?
Any good? Pics etc
Post by fossie » Tue Dec 20, 2011 8:25 pm
The 13 mm is for the adjusters on the 400 and my pop up as I've changed the bolts to ones that I cut cut a groove in so I can adjust both the same with out looking at the markings on the swingarm. Oh and it's on the other end of the 17mm , used for undoing top shock bolt when changing rear wheel, so the swingarm drops away allowing access to spindle.
Used to do valves more often but never needed anything waste of a gasket.
If you remember the stuck valve happened after I disturbed the valve by reshimming, Must have been there that long they were mates.
