just thinking......
Sergio
Re: just thinking......
Post by Sergio » Tue Oct 04, 2011 10:57 am
Pete, also have a look on 4 small rubber caps (like small black condoms) covering holes for connecting balancing tools on your carbs. They may have small even invisible holes due to age for example and make the engine work not stable.
Sergey
Suzuki GSX400SSN '93
Honda GL1200 '86
and 4 cats...
Post by johnr » Tue Oct 04, 2011 6:47 pm
no pete the cdi ignition still has mechanical advance retard. you can see the bobweights through the backplate at the top. the rotor in the middle (behind the small bolt head and the big nut) should revolve slightly as the bobweights move out under centrifugal force. if it doesnt move then its seized.
Post by callyboy » Tue Oct 04, 2011 7:04 pm
Oh i see. :roll: :roll: :roll:
I was turning the whole thing round with a spanner on the nut :oops: :oops: :oops:
Will have a look tommoz John.
Post by johnr » Tue Oct 04, 2011 7:21 pm
no, hold the nut still with yer spanner, and try and turn the rotor behind them, the but that spins between the two pickups.
Post by callyboy » Tue Oct 04, 2011 7:33 pm
Gotcha :)
Been thanked: 714 times
Post by fossie » Tue Oct 04, 2011 10:15 pm
Sergio mentioned the balance caps on the carbs , well on yours you have screws on the inlet rubbers , are they seated with a washer behind , if they draw air in there it will run lean and in balanced.
Post by callyboy » Wed Oct 05, 2011 6:20 am
I think they are ok Fossie. I got them from Bobster as my original ones were poobar and they looked ok. Will have a look at them as well.
Post by callyboy » Wed Oct 05, 2011 2:54 pm
John, checked the rotor, and its fine. springs back ok.
Fossie/ Sergio, had a look at the balancing pipe connectors and they looked ok as well.
Must be something else. maybe needs a balance.
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Post by Katgeezer » Wed Oct 05, 2011 3:31 pm
If a test ride brings you in the Welling direction, balancing can be achieved..... :D
Post by callyboy » Wed Oct 05, 2011 3:35 pm
Cheers Chris, i may take you up on that offer mate :)
