oil cooler for a 550
Post by callyboy » Wed Sep 07, 2011 7:56 pm
Looking at maybe getting one for my 550. Think it will look cool ! will a 650 one fit straight on ? looks like i already have mounting holes on the frame.
Anyone fitted one ?
Re: oil cooler for a 550
Post by bobster » Wed Sep 07, 2011 8:29 pm
I Cant see any reason why one wont fit to the 550 motor :o ...........But I dont think it will get enough air-flow just sat in your garage m8........... ;)
Are you going racing on it Pete ......or just maybe travelling over the Andes, the Sahara or Gobi dessert or even Hindo cush in the middle of summer? :lol:
You'll need the oil filter housing from a 650 too or it wont work correctly and cause more problems than it will solve! :D
Post by callyboy » Wed Sep 07, 2011 8:35 pm
Cheeky Bobster ! Although still informative :)
waltfen
Post by waltfen » Thu Sep 08, 2011 2:04 pm
The 650 oil pipes connect to the sump don't they, I would double check but mine's gone!
waltfen
Post by waltfen » Sun Sep 11, 2011 1:17 pm
odie wrote:yes the oil cooler pipes connect to the sump, is the sump interchangable with the 550?
I wouldn't have thought they would swap, they are totally different engines.
Been thanked: 714 times
Post by fossie » Mon Sep 19, 2011 6:51 pm
The oil cooler from the 650 fits the sump , but just swapping the pan over won't work as there are different passageways and a non return vale. ( Don't ask how I know.)
You could fit an oil cooler to the 550 by using the oil pressure switch , they did a kit.
Or get a sump from the last model 550.
Post by callyboy » Mon Sep 19, 2011 7:01 pm
Maybe put one on and not connect it :)
Post by callyboy » Mon Sep 19, 2011 7:05 pm
Cheers Mick. I just think it would look nice with a cooler on it :)
Post by callyboy » Mon Sep 19, 2011 7:35 pm
yep :lol: :lol:
