What have I got?
jerry
Has thanked: 6 times
Been thanked: 8 times
Re: What have I got?
Post by jerry » Mon Aug 15, 2011 8:52 pm
;) :D Thanks Bobster.....I've been sitting here sweating on that reply :D
Jerry
GSF 1200 K6 2006 Naked
Post by johnr » Tue Aug 16, 2011 8:12 pm
american spec kat 1000s got the same cvs as the 1100, this was to comply with the americans emmissions laws. at the time. the slide carbs were deemed to be too 'dirty' emmisions wise for the americans.
Richiemouse
Post by Richiemouse » Tue Aug 16, 2011 11:08 pm
I concur with all of the above. The UK 1000 Kats numbers start GS10X while the US 1000 Kats start GT72A. As mentioned the US and Canadian bikes had CV carbs and were missing the black fins under the front fairing. The slide carbs fitted to the UK 1000's were Mikuni VM32SS, I think most of the similar VM carbs fitted to the GS range were smaller bore.
What exhaust do you have?
jerry
Post by jerry » Wed Aug 17, 2011 8:28 am
Thanks John and Richiemouse, I think from what you've said and Bobsters thoughts I have a UK GSX 1000 with a few mods. As Bobster was saying at some point someone has had the slides off and replaced with CV's. As the bike was never totally original I can live with that..at some point I might try to obtain a set of Slide Carbs.
The exhaust is a 4 to 1 S/S Jama. Last question from me. I have currently got a rear tyre 120/90. All the info I have read about this suggests it should be a 130/90 :?: :)
Jerry
Has thanked: 80 times
Been thanked: 72 times
Post by sparki » Sun Aug 21, 2011 3:11 pm
s/be a 130/90 yes.... presume you have a 17" rear rim?
18" rims used a 120/90 and were on the 750's......
KOCUK - 241
Post by johnr » Sun Aug 21, 2011 3:53 pm
some merkin market kats had slightly different tailpieces with the light slightly further back, and iirc all north american spec bikes had reflectors on the side of the forks and the tailpiece. i suspect someone has in the past either had bother with the slightly odd carburation of the slide carbs and swapped them for cv's or has realised when they were selling it that a set of slides were worth selling seperately especially as the cvs were so cheap to obtain.
jerry
Post by jerry » Sun Aug 21, 2011 4:46 pm
Thanks Guys :D
Jerry
