just thinking......
Re: just thinking......
Pete, also have a look on 4 small rubber caps (like small black condoms) covering holes for connecting balancing tools on your carbs. They may have small even invisible holes due to age for example and make the engine work not stable.
Sergey
Sergey
Suzuki GSX400SSN '93
Honda GL1200 '86
and 4 cats...
Honda GL1200 '86
and 4 cats...
no pete the cdi ignition still has mechanical advance retard. you can see the bobweights through the backplate at the top. the rotor in the middle (behind the small bolt head and the big nut) should revolve slightly as the bobweights move out under centrifugal force. if it doesnt move then its seized.
Oh i see.
I was turning the whole thing round with a spanner on the nut
Will have a look tommoz John.
no, hold the nut still with yer spanner, and try and turn the rotor behind them, the but that spins between the two pickups.
- Been thanked: 714 times
Sergio mentioned the balance caps on the carbs , well on yours you have screws on the inlet rubbers , are they seated with a washer behind , if they draw air in there it will run lean and in balanced.
I think they are ok Fossie. I got them from Bobster as my original ones were poobar and they looked ok. Will have a look at them as well.
John, checked the rotor, and its fine. springs back ok.
Fossie/ Sergio, had a look at the balancing pipe connectors and they looked ok as well.
Must be something else. maybe needs a balance.
- Katgeezer
If a test ride brings you in the Welling direction, balancing can be achieved.....
