Carb woes.....again
superfly
Re: Carb woes.....again
Post by superfly » Tue Jun 28, 2011 8:30 pm
callyboy wrote:Make sure your vacumn pipe is blanked off as well !!!!
Hi Pete,
Is the pipe vacuum is the one connect from the admission to the tank ?
Post by callyboy » Tue Jun 28, 2011 8:36 pm
Sorry Arnaud, i lost a bit of that in translation :)
The vacuum pipe goes from the carb to the petrol tap. If you are messing about with the carbs with the tank off and using a reserve tank(plastic bottle and tube) then you have to blank the vacuum pipe off.
This is an old pic of my carbs before rebuild. The pipe on the bottom left with the rusty silver bolt is the vacuum pipe'
Post by callyboy » Tue Jun 28, 2011 8:44 pm
yes it does mick. but the other pipe (vacuum one that goes into fuel tap as well) has to be blanked off.
superfly
Post by superfly » Tue Jun 28, 2011 9:44 pm
Thanks a million Pete, I did know that.
I was simply reconnect them with the extension :-) like a little cheap.
Thanks for trying to understand what I am trying to ask :-)
Katman
Post by Katman » Mon Jul 04, 2011 1:38 pm
I've had that happen, made me very grateful that I always ride in staggered formationotherwise it would have taken me out :shock:
As Steve says small bolt (or screw) holds baffle in allowing fitment of more sporty race baffle ;) or indeed quite road one for MOT ;) :D :D
Post by callyboy » Mon Jul 04, 2011 1:42 pm
Mine is whacked in with a hammer ! I know......I'll get my coat :)
Katman
Post by Katman » Mon Jul 04, 2011 7:08 pm
Yep, that's a race baffle & sounds bloody luvly.
My mate used to repack his with fibre glass from the loft, worked a treat for MOT time but soon burnt off :lol: :lol:
Post by callyboy » Mon Jul 04, 2011 7:13 pm
Thats a big hole !
I put one of these in mine and it just took the edge of the noise. Gone from a very deep growl to a more raspy sound :) Got it thru the mot and i thought i would leave it in. There are all sorts on ebay. I also put a bit of exhaust wadding in there as well.
http://www.ebay.co.uk/itm/Exhaust-Silen ... 1230wt_754" onclick="window.open(this.href);return false;
Has thanked: 118 times
Been thanked: 256 times
Post by Kryten » Mon Jul 04, 2011 8:35 pm
callyboy wrote:Thats a big hole !
Thats not a hole!
This is a hole.....
That's inside this....
Not sure how I'd jet this :lol: :lol:
Katman
Post by Katman » Mon Jul 04, 2011 8:54 pm
Yep that's big Jim.
Talking of big openings (behave at the back) & yes I know it's not a Kat BUT look what I found parked outside my local hospital....now that's big :shock: :shock:
not sure if he was a visitor or patient :D
