high beam
Re: high beam
Post by callyboy » Tue Sep 27, 2011 5:04 pm
Watcha, yeah tried another bulb. same.
I am going to leave it for a while. I HATE ELECTRICS :evil: :evil: :evil:
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Re: high beam
Post by lomsavage » Tue Sep 27, 2011 7:11 pm
take all lights off and get it mot'd that way
you never go out after dark do you
come to think you don't actually ride them at all
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
coat collected
H
Hello from H
Been thanked: 714 times
Re: high beam
Post by fossie » Tue Sep 27, 2011 7:16 pm
I had exactley this issue with a 650 that someone had put twin spots on. UUUH!
Put standard light on and what you describe happened .Changed the 3 pin connector to the bulb and it is fine now.
Re: high beam
Post by callyboy » Tue Sep 27, 2011 8:12 pm
Its got a new 3 pin connector Fossie :(
I cant get my head around the fact that its pulling volts FROM the bulb up the high beam wire.As soon as i pull the high beam wire off, the dim high beam light goes off ! so it must be getting voltage from the bulb. I even took the new three pin connector apart and stuck the spade terminals straight onto the bulb in case they might be shorting on each other !!! I even measured the volts on the high beam terminal with the block off and just the earth and low beam spades connected onto the bulb, and it was still putting 5 volts to the high beam terminal on the bulb !
Bollocks. It can stay like it is.
john boy
Re: high beam
Post by john boy » Tue Sep 27, 2011 9:05 pm
somewhere in a dark corner there is a little pixie with a scewdriver
laughing
find it kill it then try it again
problem solved
electrics bloody well wizardry...................
Re: high beam
Post by callyboy » Tue Sep 27, 2011 9:08 pm
:lol: :lol: :lol:
Re: high beam
Post by johnr » Wed Sep 28, 2011 2:54 pm
have you cleaned the contacts in your switch? disconnect the bulb and then check the voltages at the bulb holder. if its still showing voltage on both high and low beam connectors at the same time, then it HAS to be the switch cos thats the next point up the line. the switch i have is from a slide carb gs550 and is similar to yours, except it has a metal casing rather than the plastic one. id reccomend taking the switch off and dropping it in an ultrasonic cleaning bath if you have access to one. cos it sounds like there is continuity between both lighting circuits.
Re: high beam
Post by callyboy » Wed Sep 28, 2011 3:12 pm
I gave it a bit of a squirt with some contact cleaner John. Will have another look tomoz if i get a chance, but i am pretty sure that i am NOT getting a voltage on the high beam wire. If i remember right i get voltage (and a dim warning light) when i connect the bulb. To me its like there is continuity within the bulb.
I dunno. Its done my head in :(
Thanks for all the help.
Am going to check all the earth connections again as well.
Re: high beam
Post by callyboy » Wed Sep 28, 2011 3:40 pm
Because this plays on my mind :( i popped out to the garage - sad git that i am.
John, I took the high beam wire off the headlight and stuck my meter on it. With just ignition on i am reading .01v when i put low beam on i am getting .03v - so some continuity then ? is that enough volts to light up the idiot light dimly ?
lomsavage
Re: high beam
Post by lomsavage » Wed Sep 28, 2011 4:03 pm
:idea:
is this an idiot light
:lol:
Hello from H
