Cdi units/igniters
tigcraft
Been thanked: 16 times
Cdi units/igniters
Post by tigcraft » Sat Oct 28, 2023 6:54 pm
Mentioned it earlier on a few platforms, I’m short of one for my 250. There’s a few new copies on eBay for peanuts (less than £20) for bandit 250s and 400s and a few more but apparently don’t fit the 250ssm which I thought it would.I asked a eBay seller who just happened to be in the far east although claims uk and said it’s a blank No!! Unfortunately I can’t compare as mine was missing when bike bought.
In reality will the bandit ones fit or has anyone got a link for a new one?
Has thanked: 122 times
Re: Cdi units/igniters
Post by Kryten » Sat Oct 28, 2023 7:17 pm
Think JohnD went through it on this thread:
viewtopic.php?f=29&t=9039
:D
johnD
Has thanked: 1 time
Been thanked: 18 times
Post by johnD » Sun Oct 29, 2023 8:47 pm
Hi tigcraft.
I can only speak for the 400, noticed some differences in the 250 engine that might or might not have an effect.
But.... There is a comonly available Chinese CDI type CDI - 11, Amazon as well as E Bay have them, circa £60- 80.
Do NOT get the £20 unit! Talk about cheaply made.....
The CDI-11 unit is very well made, better than the original Suzuki unit.... and newer!
On the 400, I had to source the timing rotor from the Bandit 400 to match, this is where I am not sure of your timing rotor type, photo might be of help.
Then, it is just a case of reversing the pick up coil leads.
(To my surprise) I have covered nearly a thousand miles this year, been caught in heavy rain, ran it on one of those broiling Sundays this summer, never a whimper.
tigcraft
Post by tigcraft » Sun Oct 29, 2023 11:16 pm
Thank you both for that info. I’ll digest it all in the following week.
Has thanked: 644 times
Been thanked: 247 times
Post by Uncle Bob » Tue Oct 31, 2023 1:55 pm
These are the same make as we have tried for the 400 and they work (link for the 250 version):
https://www.aliexpress.com/item/538071615.html
As a tip sometimes when searching use the model number GJ76A or GJ76 might do.
tigcraft
Post by tigcraft » Tue Oct 31, 2023 7:55 pm
Thank you for that and I’ll probably buy from there. I did speak to an eBay seller and gave him a GK76A ref instead of GJ purely by accident to which he said it’s suitable until I sent him the correct code then he mentioned it isn’t suitable. There must be something not right about the variation.
johnD
Has thanked: 1 time
Post by johnD » Tue Oct 31, 2023 8:34 pm
That CDI is exactly like the one I sourced. Good build quality and no failing caps like a second hand one will have.... If it is compatible with the Kats rotor and pickup wiring you are good to go. If not... its a fairly cheap and easy conversion. The E Bay units are around £60 but come with my earlier caveats.
tigcraft
Post by tigcraft » Wed Nov 01, 2023 5:10 pm
Ordered at last from aliexpress for the correct one via link. See how long it takes to appearance. I’m surprised there wasn’t a single one for that model as it had everything
tigcraft
Post by tigcraft » Wed Nov 01, 2023 5:35 pm
Btw thank you at JohnD and everyone else for links and help as the info is priceless at times for rare bikes like these.
Post by Smallkat » Fri Nov 03, 2023 3:20 pm
I just bought some tat for my BMW from Aliexpress the other month. Less than three weeks to come, taxes paid upfront, fully tracked. £30 less than the 'UK' seller on ebay.
