Floaters brakes!
Floaters brakes!
Post by fossie » Wed May 25, 2022 9:42 pm
So how did these brakes actually work without any indication of an issue ?
I only went to check because although the brakes worked fine the feel was a bit wooden .
Looks like Jimnys sock is needed!
Ooher dosen't look healthy.
Re: Floaters brakes!
Post by Smallkat » Thu May 26, 2022 11:19 am
Jeez. Thank god you have been religiously changing the fluid every two years.
Post by fossie » Thu May 26, 2022 7:31 pm
😂 Yep every 22 years religiously .....well it used to belong to a vicar 🤓
Post by johnr » Fri May 27, 2022 12:01 am
Exactly how long were they 'floating' in the canal then?
Has thanked: 80 times
Been thanked: 72 times
Post by sparki » Sat May 28, 2022 3:37 pm
at least the pistons came out :D
KOCUK - 241
Post by fossie » Sat May 28, 2022 7:31 pm
That's the bizarre thing the Pistons moved freely and just popped out . There wasn't a lot of crystallisation in the rubber boots , or pitting on the actual Pistons .
I actually cleaned the mastercyl first and bleed fresh fluid through ...They just returned to the wooden * onda feel .
Anyhow they are stripped and being painted now .....another 5 minute job eh?
