Mount plate for Igniter and fuse box
Berti44
Has thanked: 5 times
Been thanked: 21 times
Post by Berti44 » Sat Apr 23, 2022 4:42 pm
Hi can anyone confirm that 47411-08A00-000 part number is the correct mounting plate for the igniter and fuse box for my GSX750SE 1985
I bought a basket case pop up and the plate I have don’t look right. I also have two different rectifiers.
She’s slowly coming together.
Berti
Re: Mount plate for Igniter and fuse box
Post by fossie » Sat Apr 23, 2022 6:46 pm
Best post a picture of the mount plates & rectifier so we can guide better.
0800A is a pop up part number ....
But the mount plate is th same as an ES ..
As for rectifiers , one is probably from a superdream ..a common upgrade/ bodge back in to day!
Berti44
Post by Berti44 » Sun Apr 24, 2022 7:52 am
Thanks fossie for the reply. Here are the parts.
I’ve looked on the micro fiche on Fowlers website for the electrical mounting plate and it doesn’t like the one I have.
Thé smaller of the two rectifiers fits the connecter on the loom so I know that’s the original.
Berti44
Post by Berti44 » Sun Apr 24, 2022 8:30 am
I guess this is what I need and the igniter fits on here too?
Post by fossie » Sun Apr 24, 2022 9:19 am
The larger reg/rec is that from an earlier 80's bike , if it's 5 wires is a Suzuki ...possibly a Kat...if 6 wires it's a *onda .
The plate is from a non pop up katana , yes the one you need is as in the parts diagram.
As said it's easier to source one from a Suzuki GSX 750 ES ,they are the same as is the cdi , fuse box and reg/ rec ...so if you found one complete , job done! :(
Like this unfortunately without the grubbins ...but they have them as well!
https://www.ebay.co.uk/itm/313191358750 ... SwlkBgQOxL
Post by fossie » Sun Apr 24, 2022 6:05 pm
While we are sourcing parts , has your bike got an 18" or 17" rear wheel, it only matters if you are sourcing bits for the headlamp , although the reg/ rec does come onto it .
The reason people fitted superdream reg/rec was Suzuki silly idea to send 3rd phase of alternator through the headlamp switch , so if h/ lamp is off only 2 phases operate , burning out the alternator the reg/rec....
The wiring is slightly different for the 18" as the light comes on with ignition. The black boxes ( h/ lamp control) are different with one having an extra pin. 08A00 general market ...08A10 Canada and other markets that require h/lamps on all the time by law..( it was different in the 80's ...now we all all hard wired)
Berti44
Post by Berti44 » Sun Apr 24, 2022 6:18 pm
Thanks for such a detailed and informative response it’s very helpful. As for the back wheel size I’ll need to check.
I can now progress a little further.
Best wishes
Berti
Berti44
Post by Berti44 » Sun Apr 24, 2022 6:20 pm
Oh six wires so like you say Onda
Berti44
Post by Berti44 » Mon Apr 25, 2022 4:41 pm
It’s a 17inch front and rear wheel and I’ve bought the plate off eBay. 👍
Post by fossie » Mon Apr 25, 2022 7:21 pm
A 17 inch rear is General usage and parts are easier :mrgreen:
