650 jumping 2nd gear issues ?
Alexandre
Been thanked: 21 times
Post by Alexandre » Sat Sep 18, 2021 6:26 am
Hi all,
I've been contacted by a guy who bought a 650 which has issues with the 2nd gear jumping out when inserted.
On first opening the engine, he found spring debris inside the box, thought it was the source of the problem, closed the engine, but the issue was still present.
He then bought a second hand box on eBay, which appeared in good shape, fitted it... and second gear still jumps out.
Perhaps some of you can offer some ideas on what could be wrong ?
Thanks in advance !
Has thanked: 155 times
Been thanked: 679 times
Re: 650 jumping 2nd gear issues ?
Post by fossie » Sat Sep 18, 2021 12:32 pm
2nd gear issues isn't unknown on 650s , mainly because with the shaft drive you're better not running high revs before selecting the next gear ,but use the torque...
2 gear is on the same shaft as 5th gear...
Other than that borrow another linkage as if the ball joints are worn selecting 2 gear is a high travel and maybe not completing its selection.
Alexandre
Post by Alexandre » Sat Sep 18, 2021 2:26 pm
Yep, sounds logical. Thanks for the tip !
