Hi Keith,
I bought the manuals from Katana central.
http://www.katanacentral.co.uk/themodels/manuals.asp
They contain all the diagrams for the S3 and SE as well as the ES
Wiring diagram
- Has thanked: 148 times
- Been thanked: 671 times
Re: Wiring diagram
I assume you have an ES manual. Because of your last build , the SE is in the back of that , but the piece of loom from from control box to headlamp isn't mentioned, anywhere, we do have a wiring diagram for that in the club, was on the old site, it depends on the model SE you have...... However I know you have the jap one , though that piece of your loom is ok.
Your bike has a Superdream reg rec on it , and the yellow alternator wires are connected direct to reg rec, bypassing the daft Suzuki through the loom/switch set up. That is why you'll have 3 wires under the tank with black connectors on.
To return it to standard as Suzuki made in loom you'll need a new reg rec.
The ignition switch wires will be reworked because the ignition barrel was damaged and SE ones are no longer available, so a new. Switch was attached to an available switch.
The ones on eBay say SE ...BUT......
Re: Wiring diagram
http://www.katanaownersclub.co.uk/forum ... ing#p39781" onclick="window.open(this.href);return false;
This one ?
This one ?
