gearbox problem help please.
BigLT
Has thanked: 1 time
Been thanked: 3 times
Post by BigLT » Sat Aug 21, 2021 8:53 pm
After finally getting my katana on the road it was riding, handling and running beautifully, until I couldn't change gear. I was within a mile of my house so nursed it home in first.
The clutch disengages with the lever as usual, so I can wheel it around, but I can't change it out of gear.
I'm hoping that someone will point out something really stupid that I might have done, or that I should check. I had the engine out during the build, but didn't go into the gearbox.
Any suggestions would be very gratefully received....I'm not sure I can face stripping it all down.
thanks in advance.
Liam
ps gsx750sz engine with about 10000miles. Wiseco 816 kit. standard carbs jetted. Anything else you need to know?
pps - this is under resin corse kat in projects. I was about to start prepping the bodywork on the day the gearbox 'went'.
Has thanked: 148 times
Been thanked: 671 times
Re: gearbox problem help please.
Post by fossie » Sat Aug 21, 2021 11:07 pm
To be honest I'd start with the gear lever, if it's too close to the foot peg when in the selecting position it feels like the gearbox has issues . Another easy possible is chain adjustment.
BigLT
Has thanked: 1 time
Post by BigLT » Sat Aug 21, 2021 11:38 pm
Thanks Fossie, I have looked there, but I'll look again tomorrow and try different positions. I don't know why it would be working before and not now though. Maybe something's come loose or moved.
Has thanked: 51 times
Been thanked: 192 times
Post by Pedda » Sun Aug 22, 2021 12:57 pm
Have a look at the circlip part no. 32. If you lost it or it just found its way out of the notch, the gear change shaft might have moved a few mm to the rhs, pushing that little actuator gear at the right end out of action. Just a bit playin around with the gear shaft pulling it back home and securing the circlip again might do the trick.
Post by Pedda » Sun Aug 22, 2021 5:45 pm
Errm... when I say rhs I mean riding direction wise obviously, not plain looking at the pic. But I bet you knew anyhow...
BigLT
Has thanked: 1 time
Post by BigLT » Sun Aug 22, 2021 7:41 pm
Thanks Pedda. I'm going to be in the garage trying everything and praying tomorrow.
BigLT
Has thanked: 1 time
Post by BigLT » Wed Aug 25, 2021 8:58 pm
Right, errr, embarrassing admission:
Went through everything and finally noticed that the gear selector rod had 'unscrewed' itself so that the joint butted up against the bottom of the footrest when I tried to change down. I obviously hadn't tightened it properly when I was setting it.
Tightened it up, adjusted the clutch cable and it now changes fine. I rode it to Loomies and back tonight.
Thanks again for all the advice and apologies for taking up your time. At least I know I have double checked everything now.
yours embarrassed...
Has thanked: 25 times
Been thanked: 99 times
Post by Smallkat » Wed Aug 25, 2021 9:33 pm
At least it was an easy fix!
Post by fossie » Thu Aug 26, 2021 7:30 am
You won't be the only one ...how do you think we pointed you to it ;) .
There's no embarrassment in asking, that comes if you don't! :lol:
Post by Pedda » Thu Aug 26, 2021 3:23 pm
Better you being embarrassed than us, haha.
