Nice little ride out....
Post by callyboy » Fri Jul 12, 2013 4:25 pm
.......down to Chris (aka Katgeezer) today. Bike went well. Still got a knock coming from the chain I think. Maybe catching on something somewhere. Chris reckons chain is ok. Might be worth checking the wheel alignment as well.
Cheers for the cuppa Chris and sorry couldnt stay longer.
PS - Didnt get that job :(
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Re: Nice little ride out....
Post by Katgeezer » Fri Jul 12, 2013 4:39 pm
callyboy wrote:.......down to Chris (aka Katgeezer) today. Bike went well. Still got a knock coming from the chain I think. Maybe catching on something somewhere. Chris reckons chain is ok. Might be worth checking the wheel alignment as well.
Sorry about the job mate.
The chain on ratty-pop (as it's now called) is no better than yours and runs quiet.
If it's rubbing/catching anything then you should see witness marks of some sort now you've done a few miles so you'll just have to inspect the chain run and see. Maybe whip the front sprocket cover off too and check there.
Kettles always on mate :D :D
Post by bobster » Fri Jul 12, 2013 8:44 pm
Check the rear lower engine mounting bolt/ nut is not catching on the chain , if it has been there will be witness marks !
Post by callyboy » Fri Jul 12, 2013 10:44 pm
Will do Rob. Might whip the clutch cover off to see if anything is amiss.
Post by bobster » Sat Jul 13, 2013 12:07 am
Isnt that on the other side of the engine.............dont you mean sprocket cover?
Which direction did you put your engine mounting bolts through your engine? I still think it may be the chain hitting on the lower engine mounting bolt nut, if you have the bolts going through the engine from the wrong side.
I know this because I had a similar problem on one of my bikes in the past! Before you take any casings off check the rear lower engine mounting bolt nut.
Post by callyboy » Sat Jul 13, 2013 12:23 am
ok.Will do.
I meant the hydroliq hydrololic hydrodroliq hrdrodick ................the pumpy pump clutch thing cover ;)
