Re: respray cost?
Posted: Mon Jun 27, 2011 8:08 pm
by FBJ
Dream machine will be about 800. But if ya look around u should get a nice paint job for 350
Re: respray cost?
Posted: Mon Jun 27, 2011 10:50 pm
I'll know soon. got a chap doing frame on the pop up which he's done but still got brakes and stand to do.
Also he's doing the 250's bodywork in 13L ( which is listed at his local paint supplier).
At the mo he's filling in the dents and priming. Should i have got a quote?
Re: respray cost?
Posted: Tue Jun 28, 2011 1:59 am
by lomsavage
for you fossie
£3000
you can afford it
and you want it "really SHINEY"
Re: respray cost?
Posted: Tue Jun 28, 2011 12:22 pm
by JACKJABBA
If you use Dream Machine, lay down exactly what you expect of them. They wont do the bottom of the tank properly, so if you want the bottom to look as good as the top tell them. My RD500 went back 3 times before they got it nearly as good as they should have gotten it. It looks good, but for £1200 I wanted a better standard of finish. Things like insides of the fairing that can be seen had just been sprayed over, which was not what they had said they would do. Wont be using them again.
Re: respray cost?
Posted: Tue Jun 28, 2011 12:46 pm
£1200
blimey. I would want my car painted as well for that amount.
Re: respray cost?
Posted: Tue Jun 28, 2011 1:33 pm
by superfly
£1200 jaysus that is a lot of money.
To be honest, I got a quote 2 years ago for my van (traffic high and long) for €1000 including body repair and outside respray.
It sounds a lot of money for a bike, which does have a lot less paint need surface wise.
Re: respray cost?
Posted: Tue Jun 28, 2011 6:17 pm
its easy to blow over a van or car, all flat surfaces and panels, bikes are trickier, curves, multiple panels, different substances to be painted, plastic grp, metal, and the owners tend to be more fussy that its just right. the cost of materials is pretty accademic. for my two pennorth, id do it myself. lets face it, you can buy a compressor and all the gear, and spray your bits half a dozen times for under 500 quid till you get it right. 1200 quid will allow you to make a lot of mistakes, flat it back and try again to get it just so, over and over again, and at the end you know that you did it yourself.
Re: respray cost?
Posted: Tue Jun 28, 2011 6:26 pm
by Katfish
Get yourself to a backstreet bodyshop, should be able to get it done for around £250.
Re: respray cost?
Posted: Tue Jun 28, 2011 6:49 pm
by nokatanayet
i have seen this guys work ,and its good, but i have never dealt with him.
i was thinking about getting my RZV resprayed by as he done a cracking job on RZV before,
here is the note the owner sent to me.
Hi
His name is Tony Collins he is called Custom Painter on most forums.
His number is 07904585345 or 01227 719800 the company is SQ plus.
He is a funny bugger so be warned.
give him a try
