Popup Downpipes...
KatRider
Popup Downpipes...
Hi guys,
Are there any differances on the downpipes from the popup compared to some/any of the other bike?
My down tubes are mild steel and getting a bit ropey. I have a 4>2>1 stainless steel which is braw.
I don't know if i can grab any kat exhaust downtubes - or solely a popup one.
Cheers for any advice
J
J
Re: Popup Downpipes...
other Kat downpipes won't fit, so it's either popup or gsx750es/ef which use the same engine, there are differences at the silencer though so it's possible that some es downpipes might have a slightly different angle at the silencer join.
- Katgeezer
You need pipes from that series of engines (750ES,EF etc) as the SZ pipes are slightly bigger.
nokatanayet
KatRider
Cheers guys, i had a suspicion that it wouldn't be easy and that they might have a differant diameter pipe.
NoKat, are the downtubes for a 4>1 system or a 4>2>1 system? I'm trying to work out of the lengths of the pipes may be too long. (4>1 have two pipes longer as they have to reach a bit further to get to the collector)
nokatanayet
they are from a 4 into 1, don't worry if they are too long,its the too short when it becomes a problem, i'm just unsure about the angles and bends to marry up with your system
