400 ssn rear caliper
Fred
Post by Fred » Wed Jun 01, 2011 2:35 pm
One of the piston seals on my rear caliper is leaking :( :x :cry: :x
Does anyone know where i can get replacement seals or even the pistons as well.Its a 92 model,don't know if that makes a difference
Katman
Re: 400 ssn rear caliper
Post by Katman » Wed Jun 01, 2011 4:39 pm
Baz, the parts book CD should be with you any day, I posted it yesterday
Fred
Post by Fred » Wed Jun 01, 2011 4:43 pm
I've just ordered a complete piston kit for the rear caliper from Robinsons foundry for £56.64 :cry:
Thats with club discount (cheap plug). :lol:
I went for the full kit as it was only about £15 quid more than the seals on their own :roll:
Just need to find out how to bleed brakes now :?
Fred
Post by Fred » Wed Jun 01, 2011 4:46 pm
Cheers Jez, I need to get the bike back on the road sharpish to save petrol money over the car.That was the excuse i used on the mrs to get the bike in the first place :D
Fred
Post by Fred » Fri Jun 03, 2011 6:44 pm
The piston kit arrived today :D
With each piston there is one thick seal and one thin seal,ok so far.Then at the bottom i found a very small round seal ,if stretched you cound maybe just get a biro through it.
Does anyone know what this one is for :?:
Whats the best way to get the old pistons out :?: Pump one out with the pedal then grab the other one with a pair of swan neck pliers :roll: I have'nt got an air line so is there a manual way of doing it :?
Post by Katgeezer » Sat Jun 04, 2011 8:55 am
Baz,the small 'o'ring goes inside the caliper which you probably won't need to worry about unless you want to split it. If it's left un-disturbed then it'll probably be fine.
Take the pads out and pump the pedal to get the pistons as far out as possible then hopefully they'll drop out. If one pumps out sooner/further then use a G-clamp to hold the freer one which will force the other to move.
If you get any problems you know my number and I'm R/D this w/end :D
Fred
Post by Fred » Sat Jun 04, 2011 9:02 am
Cheers Geezer.
I don't think i'm going to have a chance to have a go at it till monday.Got alot on this weekend and i'm r/d monday tuesday.
So at least the neighbours won't hear me shouting and chucking my spanners out of the pram :lol: :lol:
Fred
Post by Fred » Mon Jun 06, 2011 8:17 am
The Grim northern weather has arrived down south ;) so due to not wanting to get any rain in side the caliper looks like the bike will have to wait a bit longer :evil:
But i suppose its perfect weather to get under the car and change the oil,should be dry under there :roll:
Fred
Post by Fred » Mon Jun 06, 2011 5:29 pm
The grim northern weather stopped just long enough for me to get the new caliper pistons and new seals fitted :D :D and knacker the rear brake fluid reservoir :evil:
I resently had to change the two srews holding the lid on because one was the wrong thread and the other was nearly rounded off :roll: when i did this i was stupid enough to forget to put some greese on the threads :oops:
So when i tried to take the top off today i ended up with one snapped screw and the other one properly rounded off :evil: :evil: :evil: what makes it feel worse is it's my fault :oops:
One step forward two steps back :cry:
Post by callyboy » Mon Jun 06, 2011 5:45 pm
Can you drill em out Baza ? those screws are little buggers aint they ! I replaced all my ones with allen key ones. Got a few if you want em. Whats the reservoir like ? i got a couple spare ones. got a pic ?
